22cc Cut 98-99 SRX Heads on Viper, 2 layers of head gaskets?
Since these are just slightly larger than stock which uses a stock 3 layer head gasket, should I use 1 or 2 layers of the stock headgasket?
Also going to have AAEN pipes, heelclickers and 50/40 helix.
Unfortunately most of the areas I ride in only have 87 octane available at the pumps where the sleds can fill up so I would like to set it up to run on that so I am safe.
Since I am using an SRX base gasket I guess the other option would be to use 2 layers of base gasket and one layer of head gasket.
Thoughts??
Thoughts??
