srx bigbore clutching
nastysrx
central square n.y
have a 2000 srx with a hauck 780 kit.sled has a 136 expert x with 200+ studs and long travled front susp. looking for a aggressive tail/lake clutching set up.what helix and springs would be the best?
clutching
I'm running heel clickers, Alot of weight in the heel( long bolt 5-6 washers)tip weight short bolt 2 washers, 8600. Sec roller rooster 41\37 silver at 70.Also have 8bu10's 43\39. Works well but does'nt have the snap that the trails like the heel clickers.Running a 136 track , 8 tooth drivers 22x38 gears. To 600 feet this sled is unbeaten!
i also run heel clickers .5.8g in the heel 5.7 in the tip middle empty ,red spring ,50/40 helix with green spring @60. 141x1.5 track stock gears and drivers.pulls 8500 up to 8600 on good hard pack.
Where did you find a 141X1,5 track? Have been looking for that for years.
its a stock 141 mountain max track cut down to 1.5. I'am going to 144 when this one comes apart,better selection to choose from.
i have 8bu00 with a hauck spring with 4mm engagement shim and the secondary has a 50/46 helix with a blk spring with a pink line. the problem is that when you take off the sled instantly goes to 8000rpm but does not climb up to 8400-8500 and cant pull away from a bone stock f7
