gmcdunnah
heard of notcvhing out bolt holes on "Pulse coil" to advance the timing on a srx ????
tedgoesfast
remember a little advance can cost alot of quid
valin
if you want to advance the timing, use an offset keyway.
gmcdunnah
what is a quid? lol a keyway is easier then notching? i dont think the stock class will allow a key in radar running around here
valin
The stock class will not allow the timing to be advanced. Then again, nobody is going to pull your flywheel off to check your timing in the stock class.
YAMAHIZAL700
Funny you mention. I switched out my stator last year and thought pickup coil had worn a bit but looks like someone notched it out.
Skilifter700
Whats the advantage of advancing the timing?
horkn
gmcdunnah said:what is a quid?
I doubt they would notice an offset keyway. It's not any different than the other mod you mentioned in that it still is not stock.
I heard that the first year SRX's had a more advanced timing, or that the later ones had more reatded timing. Whatever way you want to look at it.
If they're going deep enough to find an offset key, they'll find hogged out holes.
