fuel and oil gauge
04sxviper
manitoba
I need help routing the fuel and oil lines for the gauge on a 83 phazer. I'm in the process of replacing the lines on the sled and I have no idea how it goes together. I changed the lines going from the pump to the carbs that was easy but all the lines for the fuel and oil gauge have me stumped any help would be great.
I just finished doing this on my 91...not sure if it's the same. The fuel line runs from the fitting at the top of the tank just below the handlebars, down through the side panel. Then into the fitting at the bottom of the tank behind the brake assembly.
The oil line runs from the top of the oil tank, down through the side panel, and then back into the bottom of the oil tank. It's a lot less messy if both tanks are empty.
The lines just click into the side panel on the outside.
Jeff
