i have a 2007 yz450f and need to know if the mounts on the frame for a skid plate are different between the 07 YZ450f and 07 WR450f.
Pretty sure its the same.........
horkn
Tod said:Pretty sure its the same.........
The 2 bikes are almost identical. If in doubt, check it out on a fiche....
Here is what I found..
wr450
GUARD, ENGINE 1
5UM-2147A-E0-00 1 $44.61
FRONT FRAME COMP.
5TJ-21101-E0-00 1 $1,674.56
yz450
GUARD, ENGINE 2
2S2-2147E-00-00 1 $16.25
FRONT FRAME COMP.
2S2-21101-00-00 1 $2,138.15
so different frames, and different plates. It might fit, it might not.
Good luck
