Hi there i have a 98 mountain max 600, and i was woundering how do you set the oil injection on it? if any one could help it would be much appretiated
thanks!
thanks!
Having a oil usage issue?????
Do these checks in this order;
1st- set idle to 16- 1,7000 rpm's(@ operating temp)
2nd- set throttle end play to 2mm(adjustment for that is here )
3rd- set oil pump,,with engine off hold throttle wide open and look down
at the oil pump make sure alinment marks are lined up,OR just before
lining up(for less oil),your adjustment for the oil cable is here in this adjusting joint,pull back rubber sheave's and 1# is the lock nut 2# is your adjusting ring,turn 2# in or out when set lock nut 1# then replace rubber sheave's half's
4th-then set choke free play so you have at least 1.5mm of play in the
cable,that is measured similar to the oil cable,find the joint for the choke
and pull the outer tube of the cable up and measure the gap..
Thanks alot, the owner before me must of set the oil pump with out opening the throttle the whole way
using lots of oil?
raptorman2fast
Can you make the adjustments with the throttle at idle? If not, what is the alignment mark for when the throttle is not at idle?
ford428cj
raptorman2fast said:Can you make the adjustments with the throttle at idle? If not, what is the alignment mark for when the throttle is not at idle?
Not sure but this might help! Pg 8-6
http://www.yamaha-motor.com/assets/service/manuals/2000/lit-12628-02-12_487.pdf
