clutch problems
700prx
midwest
hello first time on here,i had a friend come over today with a 97 sx700
and wanted me to take a look at his clutch,belt making noise,i have rebuilt alot of cat and polaris clutches first time in a yam,anyway the primary clutch needs a rebuild wore out bushings and sliders,but thats not the big problem,his belt to sheave clearence looked huge and with the clucth open he has a 1/4" clearence between roller and base of the weight [roller has very little if any wear],you can see were the movable sheave use to start [ring mark on shaft]now it sits back the same 1/4" distance,do these spiders wear out,or movable?could the spider have shifted back on the shaft?thats almost what it looks like by the old wear ring on the shaft.not use to seeing this any ideas? thank for the help.
