YamahaSXR700
OK,
Ive check out videos on youtube of SXR's doing wheelies,
My sxr is to HARD to do wheelie Buddy must of got the strap out,
wondering if u get that out will it do damage?
yamyrider
adjustable transfer rods is what you need with the proper spacers....then you will pull the skis. The set up of the suspension will also play a factor as well as hook up...if you spin you cant wheelie.
cajones2
Yamyrider - do you know which spacers you should run with the ATRs off hand?
HitNWakes
I also have the same question. But I also have the adjustable rods from Bender. I still have to smash down my back end to bite. I have about 1.25" thread left on the end of the strap bolts. I also read to tighten the front shock and loosen the back shock? Does this make sense?
mine had no straps in it when i got it and my last sliders lastes 250 miles or 3 days
YamahaSXR700 said:OK,
