phazer fuel pump rebuild
FirstGenCTD
WA
Can I rebuild my fuel pump on my 86 phazer? Called the dealer and they said I can only get a new pump($120). Is there an aftermarket solution?
matt
I'm not sure which one was on that sled, but there shouldn't be much to rebuild, just clean it up. If the diaphragm is damaged, you can simply run an universal one. I like the Mikuni pumps (that might even be what is on it). Be sure to get the one that is compatible.
It has a mikuni pump.... You used to be able to buy a rebuild kit or even a new one from dennis kirk or shade tree.... No wheres near $120.....
