Power Valve question
jesseSRX
Cross Plains
Are all SRX power valves the same... from 98 to 02 ?
When adjusting the Power valves the Yamaha manual calls for a gap between 2.5 and 3 MM ...Here is my stupid question: If you made the gap 3 mm would you be less lickely to experience pull throughs because of less tension?
yep all srx 700 valves are the same. when you set the valve the 2.5mm is the amount of slack the cables will have when your valves are full open so no pull throughs also at 2.5mm the valve is pretty much flush with the top of the exhaust port which gives the best flow at 3mm they will be still hanging down and restricting flow a little bit.
