GS438
- Dec 28, 2004
I was out in ST GERMAIN last weekend and had something happen to my SRX I never had happen before . At wide open throttle it seemed like the sled would hit 7900 to 8000 rpm and then start losing rpm . Almost like someone was holding the sled back. Any ideas??? Trail riding was fine only when I hit the lakes wide open did this happen..
Mario
Mario
clutching need attention do a comprestion test too. plugs lean?
attakfanatik
could it be like a motor blow safe mode type of thing. i know that on my rage, attak, and nytro the computer will drop the RPM's if the engine gets too hot or about to blow
tedgoesfast
what year srx if it has a detination sensor bad fuel would do this it would be picking up a fuel knock and retarding timing
GS438
- Dec 28, 2004
Its a 2000 This thing ran awsome on the trails . I will do a compresion check . Would the power valves cause this??? I thought about the clutching but I changed nothing to cause this the last trip this thing ran strong..
Mario
Mario
Thumper1
dirty PVs?
mod-it
There is no safe mode, something is wrong.
Order I would look at things:
Read plugs, see what they say. They could point to carbs needing cleaned. Also check reeds.
Go through power valves, clean, check for pull-throughs, adjust.
Go through clutches looking for worn rollers, etc.
