Rear Heat Exchanger and Long Track Kit?
racerdan
Stevens Point
I just bought a long track kit from Tracks USA for my '02 SXR, even though It doesn't run yet. The only real question I have is will my heat exchanger work if I move it to the rear? Or will the track hit it? I thought of just putting an aluminum pipe across the back? I haven't seen any MM coolers for a long time. How have others managed with their long track kits? I don't want to hack up the tunnel extension if I don't have to. Any suggestions on a bumper? How about covering those ugly hoses?
I did mine with uncover hoses the first time till I found the hose covers off a MMax. I did cut 2 holes on the sides of the new tunnel ext to run the cooler inside......There is a lot of info on this matter here do a search and you will find pics and all.....Nick
I did about 5 different searches before posting the question. I found a bunch of posts but none that I saw answered the cooler question.
the heat exchangers i used are from an apex . i did have to shorten them and change direction of the right front outlet. they are very long and i was able to use stock apex hoses and crossover tube instead of the heavy rear heat exchanger
