Sxr Electric Start
harness racer
Val Therese ont.
I Will Be Purchasing A Starter From A Ty Member To Install On 2000 Sxr . Does The Wiring Harness Have Aux. Connection For The Starter Relay . Is The Ignition Switch Pre-wired .
Thx
wires
The plug in for the electric start is above the recoil. Depending on your kit the plugins may be different but the wires should match color code wise.
