snomomikey
When should you run with the carb heaters on, and when should you turn them off? Thanks
Unless it's very cold out OR your busten powder leave them off..
blkmax600
There has been several threads on this one, I personnally run mine turned on all of the time. They are designed to prevent carb icing. If you happen to be riding with them turned off and you notice that you are losing power and then turn them on you will melt the carb ice and suck it in the engine and scuff goes the piston.
snomomikey
Well, Those are two very different opinions. Please, anyone else lets hear what you have to say. Thanks
try a search mike too...coverd lots.snomomikey said:Well, Those are two very different opinions. Please, anyone else lets hear what you have to say. Thanks
vrwconspire
The owner's manual says to leave them on at all times except when temps are above freezing. Seems simple enough. I haven't noticed any difference when riding with them off the few times I've tried it.
Bush_aholic
I was always told anytime below -5 celsius or any time in snowy/powder situations to turn on carb heaters on nerver had a problem yet.
TJ500
believe it or not but carb ice is worst when riding in warmer temperatures than in VERY cold temps... this is because when ambient temps and dew point are close (perfect conditions for carb icing) usually happens at warmer riding temps...
when flying a piston engine powered aircraft were were taught to ALWAYS be aware of potential carb icing... at any temps.. same principals apply to carb icing of a car, sled, bike, etc...
I leave carb heat on all the time...
here's some good applicable reading...
http://faq.ninja250.org/wiki/What_is_carburetor_ice?
tj
tj
xtc700jeff
Good reading TJ, i leave mine on all the time also.
2001srx700mod
So plan and simple leave them on all the time? except in warm temperatures. Makes sense becuase the 3 cylinder genesis carberated motors like the vector and nytro etc. you have no choice the coolant always run through them.
I turn mine on and leave them on, on our Vipers. Then I don't have to worry about the carbs icing ever.
sleddineinar
I just leave them on.
yeah 4 sure always on have made several runs on radar no performance changes on or off let the green blood flow jmy r&d
We leave our carb heaters on all the time as well.
hyphyone
I've always bEen told to leave them on for those reasons +1
TopGunnSrx
I dont ever turn them on, never had any issues in 20k miles from -40-60* weather. If you feel safer turn them on.....
thefindian
ON always why would anybody even take a chance, maybe they rob a couple ponies maybe they don't but who the hell cares anyway unless your racing for money.
super1c
Super Moderator
All of ours are always on no matter what the temp. I cant tell any difference in performance with temp changes. Plus turning them on and off aint a easy task unless your a gorilla and im not messing with a wrench so on they stay.
steveg_nh
Just turned them on after reading this thread. I thought they were on though. I checked and they were off. Read the manual and it says for 32 and below, turn em on. I can't think of many times I'm riding and it's over 32...
madzx2
Mine are always off, been that way for at least three years. Never noticed any problems with it.
