I swapped out the suspension in my Vmax-4. With the help of the vmax4 website, I installed an 01 SRX suspension. After the install I noticed that the new mount locations for the front shafts were not spot on (parallel to each other). the left side is about 1/8" forward of the right side. Since the bolt is a 10mm, I really don't have the room to just drill another hole. Do you guys think I will have major problems running it as is? Any sugesstions on a solution?
