Hi guys ,What setup can I put on my sled for 500 feet drag with 40 feet of sand on start line?My track is not the best for drag it is a CONE traction.I have all this part on hand,
Weight:8DN-10 and 89A-10
Spiring primary, W-W-W | Y-W-Y | W-G-W | B-W-B | Y-G-Y | orange bender
Secondary spring: red | green | silver |
Helix:48-42 | 51-47 | 47 | 31 |
Gear:21 - 22- 23(stock)
mopar1rules
with using what you have there, i would try the 89a10's, 48/42 helix, green sec spring, and ywy or www primary spring. if you want to use the 8dn-10's, i would try the 51/47 helix, green sec spring, and ywy primary spring. you might be able to pull the 89a10's empty, w/the 51/47 helix.
go with 89a-10 with some middle and tip almost empty 48-42 should work ...just some tuning green secondary..w-w-w maybe bender orange could raise ur engagement ..or u will need to grind the weight
tedgoesfast
there are good setups in the tech pages
