regert
What would be the problem 01 srx 700 blew up middle cyl 3 times in 2000km. Looked at carbs, seals, base gaskets???? Could it be a cank seal messing up the middle cylinder??? need help on this asap going on a trip this weekend.
Thanks Regert
Thanks Regert
2strokinit
Info
WHat do you mean blew up..melted down?? DO any mods, or all stock? Plug color?
motodave289
Possable pulse hose air leak or fuel pump diaphram leaking air, if your melting it down.
Not to be a smart-aleck, but failure to determine the root cause seems apparent. This is why I stress finding the root cause before you completely tear it down and rebuild it.regert said:What would be the problem 01 srx 700 blew up middle cyl 3 times in 2000km. Looked at carbs, seals, base gaskets???? Could it be a cank seal messing up the middle cylinder??? need help on this asap going on a trip this weekend.
Thanks Regert
I would just go through the whole air/fuel supply process carefully. Not enough fuel to keep the piston cooled is the likely culprit. It is simply an air pump that needs to take a certain amount of fuel along with the air. So something is either limiting the fuel or allowing extra air into the process.
Fuel pickup / filter, fuel pump, pulse line, carbs, intake boots, crankcase seal, crankcase ventilated or perforated, exhaust restriction, etc. are all possible problems.
regert
piston melted on the exhaust side all 3 times, plug color seems to be good. I will try to get some pic's up of plug and piston.
Is it possible if the crank seal is leaking that the middle cyl would have problems but the outside cyl wont????
I don't see how . . .
Check the whole intake for that cylinder very carefully.
regert
We checked the carbs, carb boot, base gasket, block. didn't look at the fuel pump or pulse hose tho will look at those tonight.
If it ran lean why would it melt the exhaust side of the piston? Wouldn't there be melting on the top???
it will melt the exhaust side ...gaz cool down the exaust temp....what size jet are u running ???pilot .and needle clip..do u have stock air box ????
regert
sled is all stock, never did anything to it. only has a 144 track converted to it.
did u put a new base gasket last time u fix it ...in someway u have a air leak ....boot,reeds,air box not seat correctly ,or dirty carb ...maybe it run at higher temperature with that track do u have a temp gauge ???
regert
no temp gauge, have 2 other sleds have same set up one is stock and one is geared and clutched and no issues, this one melted down the first time withh the 121 on it still and 2 times with the 144 set up
then try to have a look to everything ....oil line ,gaz line ,carb boot,reed booth to base ,.... does it burn running midrange,full throttle ??..
regert
not sure when it burnt, not my sled it's a buddies. one time I know he was running about 70mph on the lake, and the last time he was running in some small powder. The 1st time it burnt not sure what he was doing.
I think he is feathering the throttle but would have to ask him and get back to you
2strokinit
Lean
Sounds like your lean and mean. I stepped up 1 size on my main jets, id rather spend a few bucks on fuel then wrench. I also run my carb heaters on at all times, unless its 30f+ Why not install a temporary egt in there or get a kit for all three. A single probe setup is still cheaper than 1+ pistons.
Some where some how its lean. Is the air box modded up or cracked? Sometimes boots look good so really examine them....its not being ran with a huge exhaust leak is it?
For gods sake dont run it so hard it melts down again. Pull the plug then get a super good light so you can see the pistons top for wash, or pull the head.
not sure jetting will solved the problem if he burn the sled on midrange and never run full throttle thats why u need to figure out where it turn lean
regert
I will see the sled this weekend and hope to find the problem with it if my buddy doesn't find it. If you could think of any other places i could look please let me know.
Is there a way to test the fuel pump with out pulling over the engine as it is apart already???
if no air leaks anywhere.....
90% of burn downs happen at mid range cruse speeds(needles)your just to
lean in carboration settings and probably bad crap fuel,check jetting settings clean carbs and use GOOD premium 93 or higher octane,watch plug color close through out all carb circuits low, mid, top..
make sure no one touch the needle clip.......
regert
on a 01 srx what should the needles be set at and what should the jets be? for a stock engine?
still need to know if there is a way to test fuel pump on the bench? is there a way to mimic the pulse ther engine creates with blowing air past the whole and pinching the line quickly?????
check tech section all stock factory setting are there....
