bravo-guy
Well guys, today I was out for a ride, and hit a rock, Messed up the trailing arm, bent up the running board and put a nice dent in the ski. Im not so much concerned for the running board, I can pound it back into shape I think, the ski is not cracked, I think its all right, but I need to know what other trailing arms will fit my sled, its 136" suspension with the 11.5" long travel rear suspension, because if I get a second hand one I need to know what other ones will fit. Thanks.
There is a letter stamped on your spindle. I had a V on mine for example. Make sure you get one with the same letter. Otherwise I heard angle might be different as well as spindle.
So make sure you get one with tha matching letter...
Nick
Nick
bravo-guy
anyone else know what will fit??? It has an "S" on the front of it.
Any Arm that has S stamping.
gild
S
Models with 6.7" Travel and 38.6" Ski Stance (Mountain Max , Phazer Mnt Lite ) anything else has a 10 degree angle shock bracket compared to your 7 degree and caster is 25.5 degrees where the older SX and SRX with 7" of Travel 40.9" Ski Stance are 23.5 degrees.
So the Stamped Letters V and M are definitely out
