SRXSex
On a 97 Vmax Sx700 I have no spark, it ran good and strong and when I put it to bed and woke up the next morning it had no spark.
I did both source coil tests and had a infinit reading across the black/red and brown leads (triangular plug). (fail)
The second test across both harnesses with the brown/red (triangle plug) to the black on the rectangular plug checked out ok. My pick up coil test came up fine.
So the question is.......
Will this failure cause a compleate loss of spark?
YamiLuke94
Have you disabled the TORS system on it?
I would say yes,if everything else checked out ok '97's were known for bad stators.i would dig into that more closely,kill and ingnition switches ok??
tors isn't the issue in this case
SRXSex
Stator
Yes the Tors Checks OK.
I have no reason to suspect ignition or kill switch, but i will check tonight.
I have no reading on the one test so the stator must have a broken wire.
Must be the stator, I will let you know this evening.
