jesseSRX
I am tired of the pull throughs!
Does anyone know how to get a hold of that Ron guy in Channahon, IL ?? I believe he has a machine shop and can permanently fix these things so they do not pull through anymore.
do a search there's a few guy's on here that do it cheap,,did you have them adjusted properly??clean every 500-1000 miles??
Skidooslayer687
You can do it yourself without to much hassle, just cut the back section off the valve and drill a hole in the center of the valve, tap it, screw a bolt into it and voila... fixed, all ya have to do is cut a slot in the bolt, round all the edges so nothing is sharp and you'll be good to go, I have one of mine fixed like this, has not been a problem at all and i've put well over 3000 km on it.
Yamahasrx700
That guy Ron in Channahon is me. PM me we will talk.
