Godster
Hello, I have not posted in a while, but have been trying to find info on something, but now may be to late. 2 years ago before the spring I did something to the engine to allow more oil to go in the engine, so as to close the sled for the summer without having to damage it when the season comes back. I didn't use the sled last year for some unknown reason, but I wanted to use it this year. I am able to start it, and theres lots of blue smoke, I remember doing something to it when I closed her down, but now I can't remember what I dd. Here is the bigger problem, I started it yesterday again to move it out of the way and it smoked like crazy (blue) when trying advance I would have to rev her really high 6500rpm, any how, after maybe 10 minutes of idleing at a very low rpm I tried to move it again and then a whole lot of white smoke and banging sounds from the engine. I turned it off right away, thinking it may be the head gasket that blew but I want to make sure. What should I do?
Dario
Dario
the banging was problaby cyl's fouling out/missing poping. you probably
held the oil pump wide open to flood the motor with oil to "fogg" the motor with a good coating of oil.
put fresh new plugs in and let her run higher idle hold the throttle 3000+ till cleared up....
Godster
Daman, I can't for the life of me locate this darn oil thing a ma jig. I know I did it I can't seem to find it, do you have a pic?
Thanks!
Dario
Thanks!
Dario
Ahh ya lost me.....pump marks???Godster said:Daman, I can't for the life of me locate this darn oil thing a ma jig. I know I did it I can't seem to find it, do you have a pic?
Thanks!
Dario
Dave M
Does the oil cable seperate in the middle like the srx/vipers do ??? maybe thats what he did was stretch the cable apart....now it needs to go back together...
yes it does,and yea thats what he could have done we don't know.Dave M said:Does the oil cable seperate in the middle like the srx/vipers do ??? maybe thats what he did was stretch the cable apart....now it needs to go back together...![]()
Godster
I really appreciate the quick responces I got from you. Yes the oil pump adjustment screw.
Dario
Dario
did you read my post number #4?
Godster
Oil pump adjustment screw and its a 95 and not a 96 not sure if it makes a difference.Godster said:I really appreciate the quick responces I got from you. Yes the oil pump adjustment screw.
Dario
Dario
Ok if you want to adjust oil pump here's how......
in order;
1st- set idle to 16- 1,7000 rpm's(@ operating temp)
2nd- set throttle end play to 2mm(adjustment for that is here )
3rd- set oil pump,,with engine off hold throttle wide open and look down
at the oil pump make sure alinment marks are lined up,OR just before
lining up(2mm)(for less oil),your adjustment for the oil cable is here in this adjusting joint,pull back rubber sheave's and 1# is the lock nut 2# is your adjusting ring,turn 2# in or out when set lock nut 1# then replace rubber sheave's half's
in order;
Godster
Daman, thanks for the information, I also put a link to a piczo site with the smoking VMAX, please have a look and see if you can see something else....it takes a few seconds for the camera to stablize please be patient, and thank you.
Dario
http://canadanationals.piczo.com/videosfrommykidswiththehounds?cr=6&linkvar=000044
Dario
sounds like you have a cyl foulded out/dead,put in new plugs check oil cable make sure it's not unseated from it's seat and run it,it needs to be cleaned out ran good high rpms.Godster said:Daman, thanks for the information, I also put a link to a piczo site with the smoking VMAX, please have a look and see if you can see something else....it takes a few seconds for the camera to stablize please be patient, and thank you.
Dario
Godster
Thanks Daman, I havent had the time to do what you advised me to do. I will make sure to folow your proceedures step by step. Thanks you for your assistance it was extremely appreciated. I will post the out-come as soon as I clean it all up.......\
Dario
Dario
