Hey has anyone found a source to get all those darn plastic bushings in the rear suspension from a better/cheaper source? Ex. centre shock and W-arm pivots and front W-arm shaft. Possibly brass or steel with teflon? Those things just do not last and it is sad how expensive they are.
Does anyonje sell a kit?
Thanks in advance for any feedback.
no i have a list of part numbers for them somewere it cost me like 60 bucks to do all bushings plus the shock bearing update .....check out BETHEVIPER he has a write up on tighting up the skid he has the part numbers wuth the write uo also ,,,,,,,
ottawaair
look at bethevipers tech on fixing all those bushings. Even when new they are loose. I did my front radius rod end bushongs, takes a little time on the first one, but is my front end ever tight now.
