any general advise on reshaping combustion chambers. im installing 433 heads on 485 cylinders. thanks...
mountainx
- Feb 23, 2004
what are you thinking about doing? just making them mach the bore or redoing the hole thing?
at this point just matching the bore. i might just copy the 485 head shape then go from thare. wadda think, thanks...
Mysledblows
I think I have a good set of 485 heads in a box somewhere. Might be sitting at a friend of mines place so it will take a couple days to find them. Make me an offer I can't refuse
Ryan B said:I think I have a good set of 485 heads in a box somewhere. Might be sitting at a friend of mines place so it will take a couple days to find them. Make me an offer I can't refuse
this is for a special project, ill let you know more later....thanks thou
mountainx
- Feb 23, 2004
That will work. I dont no the bore sizes but 2 things you have to wach is the squishband width and the angle of it. If it get to wide you will have deto probs. Not shure what your plans are for this motor but the 485 head design can be inproved apon. PM me if you need more info.
