Mounting bolt measurements
YamiLuke94
Michigan
I am in need of measurements for the skid mounts on a 97 mountain max 700. I have an sx and picked up a mm skid for dirt cheap...but I know I will have to move the rear two mounting holes to fit the skid. Any help is appreciated.
This are the measurments I have from a guy here for a 136 MM skid. I'm working on putting on a phazer.....Hope it helps.
Any chance you have the front hole measurment from top of the tunnell and from center of driveshaft.....??????? Thanks
NICK
Center - 19" from front. Center to Center
4 3/4" down from the top of the tunnel.
Rear - This is for the center hole on the drop bracket that is attached to the suspension. If you don't use them you'll have to do some math.
15 5/8" from the center hole C to C
4 3/8" from the top of the tunnel.
