edgeracer1
well the first ice race of the year s coming up and i was just wondering what the best helix was for 660 drags, sled is a 2000 srx setup for drags only. currently i am running a 51/37 but last year my sled was falling off at about 500ft mark. any help would be appreciated could this problem be the helix
helix is dependent on primary set up. There are 100 different primary set ups so that makes 100 best helix possobilities.
edgeracer1
sorry about that Turk the primary now is bender qaws,orange pink orange spring, and overdrive sheave and gearing is 20/40
BLUE DEVIL 700
i've been having great luck with a dalton 47/42 in 660feet,i still have some fine tuning to do but so far i've beaten a few Good running F7's.Im running heelclickers in the primary
edgeracer1
also running silver primary spring with 90 degree twist
not sure about your primary stuff but i think your secondary spring is not that good for it if its silver..turk will probably pop out again
9801srx
that silver at 90 is really stiff ,maybe try 70 or 60 or a green spring.edgeracer1 said:also running silver primary spring with 90 degree twist
YAMMIEGOD3:16
GO TO THE GREEN SPRING IN SECONDARY, UP TOP GEAR TO A 21 FOR 660. RUN AROUND A 48-42 - 50-40 CAM @ 80. 3:16 (yammie tony)
edgeracer1
I talked to Heath at bender and he said to run the 20/40 gearing and the silver sec spring for everything that is done to the sled.
BLUE DEVIL 700
i am running the silver as well,I settled at a 70*twist.
also have a green to try soon,but im very happy with the Silver.
edgeracer1
does anyone think that the orange pink orange spring is causing my falling off problem?
YAMMIEGOD3:16
ASK HEATH. 3:16 (yammie tony)
Danger Dog
As 3:16 said 21/40 or 21/39 and around a 50/40 helix with green spring at 70 or go with what heath said and go slow.
edgeracer1
thanks alot guys i hate it when you spend all kinds of money and what they tell you to run is not even any good.
falling off could be 2 possibilities
too much primary weight
pulled thru powervalve(s)
edgeracer1
Turk do you think it could be the gearing.
YAMMIEGOD3:16
I,LL ANSWER YA ONE MORE TIME. ITS EXACTLY WHAT TURK POSTED. HERE IS WHEN YA KNOW ITS GEARING. WHEN BETWEEN 500 F.T. AND 660 F.T. YOU GET NOSED OUT BY ABOUT A SLED LENGTH. 3:16 (yammie tony)
edgeracer1
Thanks Yammiegod3:16
Dave M
YAMMIEGOD3:16 said:I,LL ANSWER YA ONE MORE TIME. ITS EXACTLY WHAT TURK POSTED. HERE IS WHEN YA KNOW ITS GEARING. WHEN BETWEEN 500 F.T. AND 660 F.T. YOU GET NOSED OUT BY ABOUT A SLED LENGTH. 3:16 (yammie tony)
Easy now Yammi.....sometimes you can lead the hoarse to water..but cannot make him drink.....
edgeracer1
Well thanks guys for all the pointers and im sorry if i rubbed anybody the wrong way.
