quinnd
I just got a94vaxst on the chain case cap there is no dip stick how do i the oil level and how much it takes
about 1/3 from the bottom in the center of cover is a bolt, 10mm head. remove bolt, if oil flows, full. fill to a point where oil oozes out.
sandmanmike1
It tells you on the cover over the belt. Off the top of my head it is 8 oz. Best to pull cover inspect and clean thoroughly and put the right amount in. Then you can check tension as well while cover is off.
