Plastic skis on a 2000 700 Venture
radianguy
Guys I want to put a set of plastic Yamaha skis off my 09 Nytro XTX on a 2000 700 Venture(trailing arm suspension).I have searched but have not come up with a definate answer what needs to be done.
First, what ski rubber do I need to mount these 09 skis?
Second, I have heard the front end will be 1.25" lower with the plastic skis, is this accurate?
I would like to put the plastic skis on the Venture, hopefully with some help from here I can do this mod.
Thanks in advance for any help.
Ahh, found us here in the smoking section LOL
I posted on the 4 stroke side.
You can do it, but you will be lower and may need to set up your suspension a bit different. I put 98 SRX skis on my venture to keep the stock ride height. I could have bought the 03+ 4 stroke skis for less $$ than the trailing arm sled ones.
