srx dcs
norwegian
Well-known member
norway
I have a few questions about the dcs:
1) you can convert a 01 to a 02 with dcs (srx) will the result be the same (idendical function)?
2) If you jet fat enough, can you do 1 mile lake runs at WOT without the dcs going off (premium fuel)
3) Will the dcs work with a bigbore, say a CPR 780? How about 1 mile wots here?
thanks in advance
dcs
I told you it would work I have done it if you run stock jets it will come on with long wot runs when its cold like 20 degress and below it will come on all the time if you try a big bore been there done that the bigger bore changes the frequency in the cylinder that the sensor listens for
