crank bad help
DARV
Life Member
fort frances, Ontario
2000 srx 4850 milage middle rod bearing went when I call crank repair place he told me that it happen to all srx and viper's same problem what-up has anybody else have this problem.
Crank
Did the crank bearing fail or did the sled run lean and cause the bearing to give out? Dont go fixing the crank and then think its all set. Not all fail, it was mainly in the 98-99 sleds that had issues.
Normally they are fine but if it runs lean and mean its a matter of time.
