81 Enticer Ignition problem / misfire / only running on 1 cylinder?
Weez1
Quebec
Hi everyone. This is my first post. I am a new member & I was hoping someone could help me out. heres my problem:
I just picked up an 81 Enticer 340. When I took it for a test drive everything seemed ok. I got it home and it sat for over 1 week now I'm having problems getting it to run well. It has spark on both sides but really weak. After a short run the right plug fouls up and stops sparking. This happens time after time. I was going to replace the ignition coil hoping the new one would give a more intense spark but the jobbers go for around $50. Before buying one, does anyone know if an ignition coil can give a less than adequate spark or do they either work or don't work? Any other ideas would be appreciated. Thanks.
