cajones2
I have 99 600sx with 760 Hauck big bore kit, carbon tech reeds, reed notch, hauck husher triple pipes (simons), 1" predator track with 144 megabites down the middle, 23-40 gearing.
I finally got all my wrenching done, installed the hauck spec on jetting 47.5 Pilots, 160-162.5-160 mains with PTO needle at position 3, middle and mag at position 4. On paper they said this is the spec to 10 degrees. After some short testing in 0 degree temps, the plugs looked perfect. When I got on it, RPM would climb but then drop steadily until i got off the throttle. I thought this was due to the flyweights (48g HH with HH Black primary spring). Thinking it may have been the weights and clutching, I restored it all to close to what was original aside from the top gear, changed plugs and went again when it was in the upper 30's. Tested it again and the problem continued. I then checked plugs, they looked ok, starting to turning a strong tan color. Piston wash on the mag and middle pistons looked good. The PTO side looked wet on the piston crown. Plug looked more damp as well. Checked spark, it is good, took carbs off, cleaned them and also shot some shop air through them, everything looked clean and clear. I called Hauck and they said that their jetting spec is conservative and is good for more like 0 or -10. In about 40 degree temps, it would idle fine, but when you got to 6000 or so, it would get throaty and bog a little bit. As I was on the throttle and the bog came about, i hit the choke..to make it slightly worse so I am thinking i am runing too rich.
My theory is that it is running pretty fat right now. Specifically the PTO cylinder. My next step was going to be to run it again with the airbox screen/filter off to see if that helps. If it improves, I will drop main jets to 160-157.5-160. I will test it again, look at wash and plugs and fine tune by moving the needles.
Now that we have no snow on the ground, can I perform the jetting procedure with the sled on a stand when it cools down? All my clutching has been restored to a close to OEM setup. I did leave in the 23T top gear (was 21T). Surely I wouldn't think that would cause it since the 700sx for that year run that gearing. I would also think that if all three cylinders were firing well, I'd be able to run the HH weights without this type of result.
Is my plan of attack sound reasonable, anyone have experience with this kit/pipe combo or anything else I should be considering?
Thanks!
Craig
Thanks!
Craig
