No Spark for Viper
red rider
Pinawa,mb.ca
Just finished getting my viper back together. Put in a srx crank and case with the viper stator and trigger pickup. Tried to start it with gas in the cylinder, nothing. Check plugs for spark, nothing. Pickup coil measures 206 ohms and 6.6mV when cranked. Lighting coils are 0.6 ohms each. Need help any suggestions?
I just struggled with a simular situation. I tried and checked everything and when we got to the stator it was it. When it was cold it checked fine, when it started getting hot I had problems. I would just check it for the hell of it.
BWS
ohm the stator......and pull it over and test the stator for volts a yami mechanic told me you should see between 25 and 80v depending on the sled!!!!!!
