power valve cable question
YA*AM*A*HEAD
indiana
got a 99 srx 700 ....are all the cables suppost to be the same length? with the servo mounted next to the gas tank ? i think someone has switched servo motor and cables off a viper .....the reason i think so is cause there is dowel pins that align the pv housing to the jugs .....this is not shown on a srx ...olny on a viper ............i have looked at the cables on my 98 and they are about 8 to 10 inches shorter .....so i think i need to order a viper pv cable ......can anyone tell me the length of a viper cable ? for the mag side ?? roughley 28 inches ?
richard, '98 srx's 600/700 had the short cables, cause the servo motor was mounted to the airbox. the '99 600/700 srxs and '00-'02 srxs have the same cables. also, the viper cables seem to be the same length as the '99-'02 srx ones. the mag cylinder on the srx should have the longest cable, but the center and pto cylinders should share the same one....if i remember right. also, i pm'ed you.
that answers my question than .....i thought 98 and 99 had short cables ....the yamaha fish shows them as being short cables but i didnt look to see if the part number was the same .....thanks for the quick reply josh .......
