Leaky head gasket?
Tg5593
winnipeg
How can I tell weather my head gasket is leaking? I remove the spark plugs and it seems to steam for quit a while. I can see a small amont of smoke coming out , but this looks more like steam. I don't smell antifreeze, just fuel in it. Even when I blow it out it continues to steam out for about 3-5 minutes. I retourqued my head. It does this in all cylinders at all diffrent times. Is this normal?
is it going through coolant? thats normal to see that when the engine's not
up to full op temp and burning cleaner,mine does that too under certain
times when i check plugs,etc.if not using coolant run 'er!!!
