What do you guys replace your old fuel lines with,it seems every year when I take the carbs off for cleaning the fuel lines are stiff and seemingly dried out even though I replace them each year.Around here the only kind of line that's the same size ID & OD designed for small engines I can get to replace my old ones with is the old fashion clear type tubing.I guess I could put the black rubber automotive kind on but it's bigger OD and with the small brackets that route the lines under the jackshaft I'm not sure how it will fit.Is there a gas line/tubing out there that will last without getting dried out and brittle?
