I have a 1998 srx 700 that came with a comet clutch, purple spring and A-2 cam arms. I also have the Yamaha clutch with green/green/green spring and cam arms but unsure of weight( 2 different size rivets). Which clutch is better for 660' runs?
yamaha clutch hands down,you can run comet weights,poo weights in the yami clutch also with the retro fit pin kit.For 660 ft run s i would look into getting some 8bu's or heel clickers,super tips,or even heavy hitters which is basically the same profile as a poo weight and 89a10 yami weights but you have more adjutsability.
bolin22
purple spring and a-2 arms sounds like an elevation setup.
