1995 V-max 600 St Clutch Weights
SJRTX
New Brunswick Canada
JUST GOT BACK FROM LOOKING AT 1995 V-MAX 600 LONG TRACK (4300 KMS) SLED HAS NOT BEEN RUN SINCE 2000. iT LOOKS LIKE A PRETTY STRAIGHT SLED MY ONLY CONCERN IS JUST BEFORE PARKING SLED BACK IN 2000 OWNER BLEW A BELT OFF, NOT LOOKING INTO IT HE SIMPLY PARKED AND NEVER DROVE AGAIN, AFTER DOING SOME LOOKING AROUND I FOUND A CLUTCH WEIGHT WAS BROKE OFF WHERE BOLT GO THROUGHS, WEIGHT WAS SEATING IN BELLY PAN. DO I JUST BUY AND REPLACE WEIGHT AND FORGET ABOUT IT OR IS THERE A BIGGER PROBLEM( BUSHINGS APPEAR TO BE FINE) ANY HELP WOULD BE GREAT AND WHAT IS YOUR OPION ON THESE VMAX 600 ST? THKS
I have a 95 vmax 600 st and it is a great sled now you have to relize that it is an older sled so it will not ride like some of the newer sleds but when it is running right man what a blast i was out yesterday and it was -20 c out side and the sled was an animal the only outher thing is this sled will pass everything on the trail except a gas station. On a good day i get 9 mpg and when it is warm out i will get 6 mpg but that is the price for fun i guess. Now i would replace all the weights and only use a yamaha drive belt it was designed un like the aftermarket belts were designed for many sleds.
