pup55
Last week I put on a new belt and it squealed all day. Then i remembered that you have to pull out the 3 washers (shims) from the secondary clutch which I did Friday before I rode. The belt squealed only when it was warmed up and only when I start out but it did not do it every time. Any Ideas
Robnoxious
check the moter mount on the clutch side and make sure you don't have any broken bolts, or loose bolts.
pup55
will do
PNPerformance
Check your engine center to center and offset on your clutches.To see if there in spec.
all belts are not created equal you may have gotten one with tight tolerance(little short) from the factory, if ctc is on,run her,
did the end of the bolts look ok not wore??
Yamidude59
i'm gonna be puttin a gear box in my sled with a 6 speed manual tranny from a sport bike, so i don't have to worry about belts squeelin' easy install.....
always wanted to shift a snowmobile!.... not! lmao.
always wanted to shift a snowmobile!.... not! lmao.pup55
Bolts looked fine. I will run it this weekend and see how it goes.
daman said:all belts are not created equal you may have gotten one with tight tolerance(little short) from the factory, if ctc is on,run her,
I got one of those. Measured agains my other new one and its a few mm tighter, It squeled for the first 250 miles when at idle, once it wore in no more noise. PLus it now is the size of a new stock one..
i've been good just once i had a iffy belt didn't seem right took it back toDV8 said:I got one of those. Measured agains my other new one and its a few mm tighter, It squeled for the first 250 miles when at idle, once it wore in no more noise. PLus it now is the size of a new stock one..
my dealer and returned it for a new one,OEM belts are damn good but once
and a wile your see this..
pup55
I should have measured before I put it on, but you know what happens when you assume. I'll keep riding and see how it goes.Thanks guys
