I Just Took Off The Airbox To Do The Reed Notch Mod And Noticed Oil Inside The Box Is This Common? It Isnt Alot Just Curious Why It Is There?
98srx6
Its normal. I believe it is refered to as spit-back and is caused by the reeds not stopping all flow in the wrong direction. You can check your reeds for cracks or broken petals if you want some reassurance.
boost bottle will cure most of it.
