sickric
I was adjusting the spring tension of the rear shock on the skid today. While I was looking around under there, I found a hairline crack in a weld on the right lower side of the W arm ( weld around pipe/ tube that has a bolt and shaft) Has anyone had this problem ?
harness racer
yep its very common problem get it plated and it will be better than stock!!!!
^^ x2 happens alot,tho i've never had it happen.(i don't jump my sleds)harness racer said:yep its very common problem get it plated and it will be better than stock!!!!
WHAT!!! You don't jump your sleds.Betcha your springs haven't even compressed yet.
lol...
daman.when are you opening up your museum for your sleds.Be sure to incase them in glass so no dust gets on them.Then you can charge a fee for people to come in and see the sleds that never were used to their capacity.
700
Sorry daman but I gotta agree with bluemonster on this one. Ain't nothin' like jumpin'!bluemonster1 said:WHAT!!! You don't jump your sleds
sickric said:I was adjusting the spring tension of the rear shock on the skid today. While I was looking around under there, I found a hairline crack in a weld on the right lower side of the W arm ( weld around pipe/ tube that has a bolt and shaft) Has anyone had this problem ?
Very common, There is a thread on here about bracing, I used the 3/4 in angle iron and flat steel method, No problems since.
If you shocks are shot and your bottoming real hard over whoops or bumps, it will crack the arm also, Not just jumping.
Yamasquaw
- Jan 8, 2005
I have probably went through a roll of mig wire on my suspension!! haha
RIVERRUNNER
there's 10 lbs added.
RIVERRUNNER
Better then a night spent out in the woods!!
that is true...lol
HEY WAIT A MINUTE!!!!!!! THAT statement is flawed!!!RIVERRUNNER said:Better then a night spent out in the woods!!![]()
RIVERRUNNER
Sxr700Bandit said:HEY WAIT A MINUTE!!!!!!! THAT statement is flawed!!!![]()
With you guys I can never win!!!LOL
your lucky only a hair line. I had mine in three seperate piece in my hands last year.
FYI
also take apart the bottom front shock mount as that weld also breaks. Well, Maybe it was just me.
But better to be safe and check it vs not and getting it back in and finding out that you have to repeat.
FYI
