Coolant bleeding(red head triples,'97-'01 twin)
Bad Axe,Michigan
Step 1,
1.remove seat,and bumper cover
2.lift up back of sled slightly higher than motor
3.remove bleed bolt on rear heat exchanger
4.Slowly add coolant in the hose(fill port ),allow the coolant
to drain out the bleed hole until all air bubbles disappear, re-tighten bleed bolt set sled back down.
Step 2,
1. loosen/remove the bleed bolt on top of the thermostat housing(head)
2. Add coolant and allow to flow out bleed hole until all air bubbles
disappear.
3.tighten bleed bolt, make sure system is full and cap is on.re-check
coolant level.
Step 3,
Start the engine and run @ 2500 to 3000 rpm's till warmed up and
coolant circulates good, check heat exchangers should be warm
to the touch.after sitting over night and top off (a) if needed.
if air is still expected repeat above steps..
make a ramp in your back yard and JUMP them sleds for the first time,maybe your springs will compress enough and you'll have to go and re-paint them again.I had a wild time today with the 600.Pinned to the bar all day,river running,ditch banging,even some boondocking in some 2 foot powder.Jumping driveways was the most fun,was airborne pretty damn good.The 600 performs great and even got it up to 93 mph today and she was purring.Man I love that 600,it just won't quite and nearly 11,000 km's on it. ;)!
daman,if you are bored,what are you doing on the computer when your wife is in the other room.Do you want her to smash that computer over your head again...lol
flatblack97 said:
My 97 twin doesn't have a rear heat x-change, just the side rails and the one in the front.
you still have the rear bleed port on your cross over tube,same thing it's there.
