96 indy trail
marty f said:
how do you adjust the secondary on an indy trail are ther adjusters?
Loosen the three bolts (part 12) and turn the adjuster cam (part 11).
Tom
Did you recently replace the belt? If you loosen the three bolts and turn the adjuster (counter clockwise if I remember correctly) it should fix the problem. The track should just barely want to spin when it's on a track stand once adjusted properly.
