Coolant and Oil empty after sitting 1 year??
CGC419
Need some advice, I'm getting my Mountain Max up and running, it hasn't been ran for over a year. I noticed last night both the coolant reservoir and oil reservoir are empty, also no coolant in the hoses by the cap. Also I'm putting my exhaust pipes back on and notice a drip of green antifreeze on the mag and pto exhaust ports. Any ideas on any of this?
for the coolant in the exhaust ports, i would have to say possibly a leaky head gasket and for the oil all gone, a few things are possible. did you just run it near empty before it was last parked? LOL. is there a puddle of oil in the belly pan, to indicate that there is a leak somewhere?
Whats odd is there is no sign of oil stains or coolant anywhere on the sled or my garage, except those couple drops in the exhaust. I'm about positive it wasn't empty when I parked it.
Time to open it up and see what happend then, If not there then the rodents took it home for a cocktail.....Nick
if it was in a hot barn ...i have seen pressure build up in the oil bottle and push the oil threw .....check to see if the fuel pump is full of oil or the carbs full of oil ...........just a thought
