viper mountain heat exchanger problem!!
Vector88
Labrador, CANADA
hey
i recently got a small crack in my left side heat exchanger and its right under the drop bracket in the rear. now i got a leak in the same spot on my right side heat exchanger. i was wondering if anyone else with vipers or viper mountains had the same problem. if so how did you fix it from happening again? also i was wondering if anyone has a set of hartmaninc or mountain performance drop brackets that i can put on.
