blew by you
I have a broken wire right at the clip for the dummy light thermo sensor.It would be difficult to sodder because it broke flush to the plastic.Anybody know how to fix this?
Not sure on your connector but most have a brass terminal that is inside the connector. There is a locking tab inside the plastic connector that holds the terminal in the connector.Get a small eletronics screwdriver and grind it to a long flat blade. Insert it the the other side of the connector (sensor side) and push at diff. angles or sides until you release the locking tab. Once out you can solder to the terminal again.
jaws jr
The pins look identical to gm automotive, most GM dealers have the terminals on hand. Take yours out and compare.
