SX_SLAYER
ok guys... ive got a ton of questions... so ill compact them to this 1 thread....
SLED: 1997 SX 700
plenty of mods... dont feel like listing..... say about 120hp..... .8" 121" track... no studs
Q1: will a 1995 440 snopro be able to beat me off the line??
Q2: 2002 articat 500 mountain 136"..... thoughts (good, bad, terrible?) and how will my sled fare against it?
Q3: my odometer, tripmeter and speedometer stopped working today.... what should i check... and how hard is it to check?
Q4: has anyone ever seen a "dirt bike" seat mounted on a yamaha (SX,SXR,)
i know a company makes them for artic cats........ im looking into making one with metal tubing and a dirtbike seat.
SLED: 1997 SX 700
Q1. I think you'll be fine, but there is only one way to know.
Q2. I hate Kitties, no coments here.
Q3. Most likely your speedo cable on the side of the driveshaft has gone bad. You have to remove the 3 bolts and inspect, you might need a new bearing at this point.
Q4. No I haven't seen one, cool idea tought...
Nick
Nick
Q1: yes..anything can beat anything if setup rightSX_SLAYER said:ok guys... ive got a ton of questions... so ill compact them to this 1 thread....
SLED: 1997 SX 700
Q2:thats a cat yours is a yamaha........nuff said!
Q3:check the meter housing that bolts to the tunnel..they will go bad
Q4: are you kidding?
SX_SLAYER
no yammy im not kidding about the seat..... its called a "freestyle seat" id like one in place of making a seat riser
yamaha_snopro
to your question 4, yes i have one mounted on my sled right now. the frame is made of cro moly and the seat is yamaha dirt bike seat. ill post some pictures next weekend.
SX_SLAYER
k thx yamaha_snopro
YamahaSXR700
Q3 check your connector in ur drive sprocket int he bottom of the sec. clutch if the connector is gone u need a new bearing
SX_SLAYER
bump.... i want more answers if possible =)
braindead1684
If you tach and everything is not working it seems like something might have came loose on the cluster and not just the speed o housing.
SX_SLAYER
tach still works
The three things all drive off the same part. So either the gauge went bad, the cable, or the speedo adapter at the driveshaft.
