VDO wiring
I have one on my srx if no one else chimes in between now and then Ill take a look and let you know on Tuesday nite when I will be doing some work to mine.
How are you hooking up your battery???
Bill
Dan thx for the manuals.. Turns out my problem was with the voltage regulators on the sled.. Finally have a working tach... Now the clutching begins, hope to run on the 8th of March at Rockies... You should try to make it out to one of the NBSSR events.. Last one in NorthBay should be a good time.. Would like to see a good running v-max up here again.. Hasn't been a runner here in a while.. SRX's tend to fly the Yamaha flag up here..
