pinboy122
hey,ive been keeping my eye out(ouch!) for a set of triples for my 97 sx and I noticed that slp"s wont fit sleds with reverse.Will anything fit?Also,will the reverse have any effect on future re-gearing? Ive never opened the case on a reverse sled. thanks al
taylzee
Depending on what type of SLPs? I had the three into one on a 2001 mm700 with reverse and they fit. It was tight but it worked. The Benders will fit and so will the end dump PI pipes. Not sure about the others!
pinboy122
I dont have any specific pipe in mind,but i looking for something used and not excessively noisy.i just dont want to get stuck with something that doesn't fit.
I have benders and no problem with reverse....And usually you don't need to re-gear with new pipes, just some clutch and carb work.
Nick
Nick
taylzee
The SLP three into one pipes weren't loud at all. The Benders are a little louder than SLp and PI end dumps are obnoxious!
pinboy122
The pipes im looking at are slp 3into1,has anyone fit them into a reverse sled?
gild
3x1
I have SLPs with reverse and it does fit but would buy Benders next time.
Gearing , reverse comes with a special 39 tooth bottom gear not interchangable from Yamaha so gearing changes is by top sprocket only,
FYI electric start is also a pain with SLPs
MountainRx1
I don't think that PI end dumps are obnoxios, I think they sound pretty awesome. Try Cpr's or the earlier Haucks(same pipes) Those fit no problem with elec start and reverse.
taylzee
I didn't say they don't sound awesome, they are loud though!!!
