JeepJimmy
wondering if you got any pics of SRX's with Viper shocks??? looking to see how different it is.
JeepJimmy
anyone?
Coldplay97
Life Member
if you need a photo betheviper used to make a bracket (I thought) to use viper shocks, pm him and he may have a photo....CP
JeepJimmy
working on it. anyone else?
JeepJimmy
looks like it sits higher then a VIper? what did you use for front shock upper mounting?
Those are standard length long travel/viper shocks in front, but the rear has the long travel shocks with 2.5" drop brackets. I do have the front springs turned up quite a bit more than stock to lift the front a touch.
JeepJimmy
what kind of top brackets did you use on the front shocks? also did you widen the front or leave it alone? thanks JIm
