cougarguy
On my 2000 VMax 600, the previous owner jammed a metal rod into the driveshaft to turn the speedo gear instead of getting the proper spline. Now it has sheared off inside the driveshaft. I'm wondering how's the best way of getting it out. Michrofiche shows a connector plug tapped within the driveshaft so it is as easy as drilling it out. Is this connector pressed in, threaded in, etc? Any advice is appreciated.
